Floodlight camera - can't factory reset or get it to sync
  • 15 Replies
  • 16979 Views
  • 19 Likes
  • 10 In Conversation
Mayhill
Hi
New camera - got it working but it then seemed to lose ability to connect so I have deleted it from the web service and tried re-sync ing it - but I cant get it to go into sync mode (blue light flashing)
Just get slow blue light every few seconds.
Tried the sync button to factory reset but no go - battery out and back in
Any advise please?
15 REPLIES 15
Mayhill,
Is there any error message when attempting to sync? Try charging the battery and then attempt the sync process again. Do you still experience the same behavior?
Frustrated66666
I have exactly the same issue.  Need help.
We need all details to be able to help.
Frustrated66666
I am having trouble connecting an Arlo Floodlight to a new network.  I would like to be able to put the floodlight back into factory reset state and try from beginning.   How do you do this?
144edward
I have exactly the same problem too. Dropped off, so I removed and tried to factory reset and it doesn’t reset
Frustrated66666,
You can change the network your floodlight is connected to from the mobile app. Log in and navigate to Settings > My Devices > select your floodlight > Connected to > Change Network.
Frustrated66666
The device is not connected yet.  And I cannot sync it to add.  Hence, my request to put it into factory reset, because it appears confused.
To factory reset, press and hold the sync button until the LED flashes amber and the camera reboots.
Christie77
Did you ever get a response or figure it out? I’m having the same problem and it won’t reset at all 😕
Christie77,
Are you able to provide more details about what you are experiencing? LED behaviors, error messages etc.
SamSC
Similar problem with an Arlo pro3. Took it over to charge it and it dropped network. Battery out left it out for some time. Back in. Still not on network. Tried plugging it back in. Tried factory reset. Never get amber light. It's like the button isn't even being pressed. Occasional blue light flash. Suppose the sync button use broken? This is the camera that lives inside on a shelf. No elements, no extremes, just a comfy life. Any advice on fixing the camera appreciated.
It might be that the battery doesn't have enough charge.  If you have another camera, you might try swapping the battery and see if that changes anything.
Note that if the battery is totally dead, getting it to charge can take some finagling.  You might need to try removing the battery, adding it back, and then connect it to the charger several times in order to get it to start charging normally.
SamSC
Let the device sit in the charger for 2 hrs. Took the battery out for ~2 hrs. Battery back in and it started responding correctly.
Diego1234
Are you still having trouble or is it working now?. I have same issue. 😞
habyfamily
Same here for a long time. Keep plugged in to charger. Swapped the unresponsive / unfactory_resettable camera’s battery with that of a 2nd camera on the network that is working. The second camera worked great immediately (ie wasn’t a battery issue at all) and the “dead” camera still won’t factory reset with the ‘new’ battery.
I thought these things were supposed to be simple!!! Help anyone?!?
  • 15 Replies
  • 16980 Views
  • 19 Likes
