Curious what is the maximum height one can mount the Flood Light camera?
I have the Arlo Pro 2 cameras, which if mounted at a height of above 12 feet do not seem to have accurate results ever.
I eventually had to lower the height to 8 feet max in order for notifications to pick up movement.
Having a camera this low is just easier to be knocked off by potential burglars.
Arlo recommends 7 feet. I have some lower that detected better when lowered. Also on PIR cams detection is best across the FOV rather then head on.
Arlo Pro 3 Floodlight
