Floodlight will not scan QR code
  • 17 Replies
  • 9071 Views
  • 8 In Conversation
Frustrated007
I cannot get the camera to scan the QR code. Super frustrating. I have tried everything I have read in other forums and nothing is working. Bout ready to return and go with different brand. Any out of the box suggestions? Thanks in advance.
17 REPLIES 17
michaelkenward
Sensei Sensei
Sensei
Are you adding the floodlight to a hub or to a wifi access point?
What happens when you try?
Just another user
Frustrated007
Well, I have older Arlo cameras, so when I tried to connect to the hub it said my hub was too old. So then I tried to connect via WiFi. During set it up, the step I am stuck on is scanning the QR code then listen for beep. But the camera will not scan. I have changed the brightness on my phone, taken a pic and zoomed in, moved the camera back and forth, tilted the phone around. Super frustrating. Thinking of taking it back and going with another company. Thanks for any additional insight
michaelkenward
Sensei Sensei
Sensei
And that hub is? The model number?
When I set up my floodlight, I did it on a PC rather than a mobile device.
One thing to bear in mind is that it may help to force the mobile device to use 2.4 GHz wifi. The camera uses that. The device needs to be on the same network. Not knowing what your local wifi is like, this is just a guess on my part.
Out of interest, does any other brand make a floodlight that will tie in with your existing Arlo cameras?
Just another user
Take a look and follow the QR code troubleshooting steps listed here: My Arlo device won’t scan the QR code when I am connecting it to a router; what do I do?
Frustrated007
Dude I am so far past that list it’s not even funny
Frustrated007,
Try factory resetting the floodlight. This can be done by pressing and holding the sync button for 15+ seconds until the amber LED flashes, then release. Try on-boarding again and let us know if you still experience the same behavior.
TSA
James, I am having the same problem. It stopped working so I removed the device. Tried setting Back up and Won’t it won’t scan QR. have tried the factory reset and it just has a blue light every 5 seconds or so and the QR won’t scan. My phone is connected to 2.4ghz. Sent a request for support 3 days again and no response. Any other ideas before I take back to Best Buy?
TSA,
When you say it stopped working, what behavior were you seeing? What prompted you to remove the device?
When attempting to factory reset press and hold the sync button for 15+ seconds, after the camera reboots, attempt onboarding again.
TSA
The camera was offline. I though the battery may have needed to recharge so I removed it and charged it. After several attempts to get it to work, I removed the device and tried to setup as a new device. Now it is not scanning the QR code.
TSA,
I've escalated your open support ticket and requested a status update. An agent will be reaching out to you with more information as soon as possible.
Stevess31
I had the same problem. Customer Support got me to turn off VPN on my iPhone and the QR scanned immediately that had taken effect. All solved!
Kingsnow1831
My camera said offline so I tried to reset it and reconnect it and now it won't scan the qr code. I've tried factory resetting, adjusting the brightness, turning off my VPN and it still won't connect. Should I just take it back and try a different brand??
Kingsnow1831,
Have you tried charging the camera? What is the LED behavior when you are going through the setup process?
madona
I'm having the exact same problem. Camera was working fine than went offline. I too tried recharging the battery, but it still would not connect to the router. Removed the device to re-install and it won't scan the QR code. Please let me know if you have any success.
Thank you.
Stevess31
I eventually did a restart on the router and then the Arlo floodlight QR code could be read. Takes many attempts sometimes but after switching everything off for awhile and the restarting seems to work. Good luck!
Citywide
My camera also randomly went offline and stopped working. I tried reconnecting it again and nothing works. I contacted customer service and opened a ticket and nobody can’t help me with my problem. Can someone please tell me what to do and how to make it work again.
Citywide,
What is the LED behavior on your camera? At what point are you seeing an issue? What error messages do you see?
  • 17 Replies
  • 9071 Views
  • 8 In Conversation
