Floodlight will not scan QR code
Are you adding the floodlight to a hub or to a wifi access point?
@Frustrated007 wrote:
I cannot get the camera to scan the QR code.
What happens when you try?
Just another user
Well, I have older Arlo cameras, so when I tried to connect to the hub it said my hub was too old.
And that hub is? The model number?
When I set up my floodlight, I did it on a PC rather than a mobile device.
One thing to bear in mind is that it may help to force the mobile device to use 2.4 GHz wifi. The camera uses that. The device needs to be on the same network. Not knowing what your local wifi is like, this is just a guess on my part.
Thinking of taking it back and going with another company.
Out of interest, does any other brand make a floodlight that will tie in with your existing Arlo cameras?
Just another user
Take a look and follow the QR code troubleshooting steps listed here: My Arlo device won’t scan the QR code when I am connecting it to a router; what do I do?
Frustrated007,
Try factory resetting the floodlight. This can be done by pressing and holding the sync button for 15+ seconds until the amber LED flashes, then release. Try on-boarding again and let us know if you still experience the same behavior.
TSA,
When you say it stopped working, what behavior were you seeing? What prompted you to remove the device?
When attempting to factory reset press and hold the sync button for 15+ seconds, after the camera reboots, attempt onboarding again.
TSA,
I've escalated your open support ticket and requested a status update. An agent will be reaching out to you with more information as soon as possible.
Kingsnow1831,
Have you tried charging the camera? What is the LED behavior when you are going through the setup process?
I'm having the exact same problem. Camera was working fine than went offline. I too tried recharging the battery, but it still would not connect to the router. Removed the device to re-install and it won't scan the QR code. Please let me know if you have any success.
Thank you.
Citywide,
What is the LED behavior on your camera? At what point are you seeing an issue? What error messages do you see?
Arlo Pro 3 Floodlight
