  • 1716 Views
tonyhua
my floodlight connects with VMB5000
and It's usually lose signal anytime of the night
my setting: smart notification "Human only"
and if a cat or a dog or animal goes by it will activate the light
I can see 80% of the lose signal are after a footage then It got disconnected and it drains battery until the next day, I have to recharge it
I through it might too far from the base, I put closer but same issue
my Ultra 2, working  fine. even I put it very far
I think the footlight have some bug with LED controllers
Yes.  The camera has to capture the video, and then send it to the cloud to be classified.  So the light will go on whenever the camera triggers at night, and the video will be streamed to the cloud for analysis.
Do you see any issues (buffering, etc) when livestreaming the floodlight?
tonyhua
the footages are very good
nothing to concern
after it got disconnected I see there is a small red LED light in the front and no other LED up
but battery is being drained inside
sometimes recover by itself, but very are
Arlo have to rebuild this device, floodlight pro 4 maybe
thanks
tonyhua
the livestream is good
  • 1717 Views
