  • 1678 Views
JoAustralia1
My floodlight has stopped showing recordings in the library. Please help I have tried everything to fix it to no avail  😞
dcfox1
Did your 3 month trial run out? It need a subscription for cloud recording.
JoAustralia1
Yes it just ran out but I only want local recording. But it will no longer record and store in the library. 😞
dcfox1
Not sure if you set it up but you can check this link out for help. Also the Pro3 Floodlight must be connected to the hub, not you wifi for local storage.
What is Direct Storage Access and how do I use it? (arlo.com)
  • 1679 Views
