Even with solar panel, all setting to save battery. Camera records constantly and drains battery
The options to address this are
- position the camera to reduce or eliminate the unwanted motion from the field of view. Note the camera is more sensitive to side-to-side motion, and is more sensitive at the bottom of the field of view than the top.
- reduce the motion sensitivity
- reduce audio detection sensitivity if you use it (or just disable it).
Note that setting up activity zones and smart notifications won't help battery life.
I’ll try that . Thanks!!!
Arlo Pro 3 Floodlight
