Dropped floodlight
I dropped Pro 3 floodlight from 10’ ladder. A small black piece popped off that covered electrical connection. I snapped it in place. The floodlight operates but the picture is a little blurry.
Any suggestions?
After making sure the lens is clean, it may be that the lens or sensor has moved slightly causing this. I don't know if you can get a replacement but it may be worth trying. Use the app to go to Settings, Support. Select the camera and scroll down to Contacts to see what official support may offer.
Arlo Pro 3 Floodlight
