Floodlight and cam supported by WiFi panel worked flawlessly for six months. Then battery notice. WiFi panel no longer supporting it and battery lasting only one day. Help!
Could be a faulty panel but try cleaning both p[arts of the magnetic connector with alcohol and reseat the connector carefully. Any better? If not, disconnect the panel to monitor battery usage to see if that's normal.
Also, what are the ambient temps? The battery won't allow charging below freezing.
Arlo Pro 3 Floodlight
