Arlo pro 3 Floodlight - light will not come on
I purchased an Arlo Pro 3 Floodlight and set it up with my VMB4000 base station. It sets off alerts when it detects motion, but the light will not come on. I purchased this camera to replace an Arlo Pro 2 to catch trespassers. The Pro 2 works, but the night detail was s not good enough. The Pro 3 Floodlight is essentially useless. The firmware updated when I set it up. Any advice?
A couple of points:
- Movement will not activate the light during the day
- You need to have a rule to Turn floodlight on when Motion is detected
The Floodlight differs from other cameras in giving you separate control of the light and the recording.
Just another user
@Wallacepark wrote:
I have the light sensitivity turned to the most sensitive and the light is turned on.
What does that mean?
Nowhere in your messages do you mention rules or modes.
This is the place to look:
That's on my Android app, but the browser interface is the same.
You have to tell the floodlight to turn on when it Detects Motion. There is also a Record video setting.
Perhaps you have done this. But it is not clear to me from this conversation.
Just another user
