Arlo floodlight unable to record video
  • 9 Replies
  • 2744 Views
Aussiefishy
Hi all,
I have a question on the floodlight. I have no subscription plan at the moment and have a total of 5 devices connected to the hub. The option to record video for the floodlight was greyed out. Does the floodlight requires a subscription in order for the video to work? It certainly come as a surprise as the cost of the floodlight is significantly higher than a comparable camera yet a cam alone have video recording for free...
Please help!!
9 REPLIES 9
dcfox1
Are you saying it is greyed out in live steaming or in modes?  If Live steaming you cannot record when 2K  live steaming is active in settings. If you turn it off you can.  If you connect to a Smart Hub or Base you can get motion recordings locally as you stated you are connected to.  Are you getting local motion recordings if that is what you mean.
Aussiefishy,
For recordings to be saved to the library, your floodlight must have an active Arlo Smart subscription. For more information, take a look here: How do I subscribe to Arlo Smart?
dcfox1
@JamesC  Just curious if connected to a Hub like he is would the record option still be greyed out in rules for local recordings?
dcfox1,
Local storage would need to be enabled on the SmartHub/Base Station to enable recording without a subscription for the floodlight.
dcfox1
Wasn't sure if it would still be greyed out. Thanks.
Aussiefishy
Hi James
How to activate local storage?
Aussiefishy
If I install the USB drive to record will I be able to see the recording via the app? How do I access these recorded videos?
Thank you
dcfox1
Thank you
Not previous ones but you can once you set it up you can via the library in the app by selecting Hub instead of cloud. The link posted earlier by a mod explains it.
  • 9 Replies
  • 2745 Views
