Arlo floodlight notifications when disabled
  • 5 Replies
  • 2406 Views
  • 5 In Conversation
Nate3523
Hi guys,
A few weeks ago my Arlo floodlight started sending unsolicited motion notifications on 2 phones after 6pm daily even though it was only set up to send smart notifications when a person was detected . All other cameras are ok.
Have tried the following to no avail:
-Rebooting base station and floodlight
- remove camera from smart notifications and disabled push notifications.
-Changed to custom mode
After trying all of these things I am still getting these notifications come through even when notifications are completely disabled from that camera.
Any suggestions would be appreciated.
5 REPLIES 5
Maybe try a factory reset.
CanadaNB
I have the same issue, as soon as it gets dark enough for the floodlight to turn on, I get notifications even though the push notifications are turned off….very annoying as I live on a busy street
Nate3523
Still happening for me, only after 6pm which is odd. Haven’t been able to work it out.
Try toggling the push notifications off/on/off again to see if that helps.
The development team is working on a solution for this issue. I will provide an update as soon as I know more.
You can also follow the bigger discussion on this issue here: https://community.arlo.com/t5/Arlo-Pro-3-Floodlight/Annoying-alert-Arlo-secure-notification/m-p/1872...
  • 5 Replies
  • 2407 Views
  • 5 In Conversation
