- English
- Floodlights
- Arlo Pro 3 Floodlight
- Arlo App beep twice for only 1 notification also s...
I am receiving double notifications from my camera.
I have the latest app 2.23 on iPhone I have the latest firmware on camera I have restarted the camera I have rebooted my phone I have removed app and reinstalled
It maybe because I have recently updated to iOS 14.4, but the issue is still persisting. I am getting this on both my my iPhone and iPad?
Is this a common issue or just locally to my phone and iPad?
this only started 05/02/2021 since I updated my iOS device firmware software |
For those experiencing this issue, please make sure you have the latest version of the Arlo mobile app installed from the app store (as of today that is version 3.2). If you are still experiencing this issue after updating your mobile app to the latest version, please let us know the details so we can investigate further.
I am having Arlo App installed since more than 2-years but this problem started last week. Arlo app is detecting motion for each camera and sending notification but beep twice at the internal of about some seconds. I am having four cameras installed and it's really annoying for me. Also, surprisingly, other mobile's apps is stopped showing notifications but we can see the video clips old/latest using App.
I have logged off from the Arlo App, uninstalled it many times also restarted my mobiles every time after uninstalling the app. I've also change my Mobile setting (Arlo & messages) and change my message setting to "Repeat Never". Restarted Arlo Smart hub many times but nothing change.
I contacted Arlo support, been told that they are going to escalate the case. Hope they will come out with some solution of this problem soon. Mean while, is anyone having or had same problem
I've logged into other Mobile and having the same problem.
This is happening to me too, started a few days ago, updated my iphone software, and it's still doing it. It's really annoying. Hope they fix it soon.
Had a message from support asking me to go to setting>notifications>and turn “repeat alert” to never at the bottom somewhere. Could not find option on iPad or iPhone.
I then spoke tho Arlo chat, where was advised to go to a setting>notifications>messages and turn “repeat alert” to never?
I explained that I wanted additional notifications for my messages, but not for arlo.
advised me that sometimes iphone thinks arlo thinks it’s a message?! Anyway, I did as asked with no resolution, issue still persists.
another item I found missing is that when a notification was send previous to iOS 14.4 update that you would have a green box around movement of car, person, animal, (and previous to that app update was a greyed out box), but now there is nothing but the thumbnail, was told this was the intention due to recent update (which was not issued in last couple of days).
feel like I was fobbed off.....
I believe this is an arlo conflict with iOS 14.4, which needs correcting, and until an app update is used nothing will change.
An update to this thread.
I am still getting the double notifications, with no resolution. However have noticed that the first notification sounded has the green box around the object moving in the thumbnails notification, and the second does sounded does not, with about 10 seconds between sounded notifications.
I only get 1 counted badge per notification, but alert sounds twice with pop up on home page.
still waiting for Arlo to get back to me after rejecting their initial suggestion, of which they state a replying within 2 days.........
Not sure if it makes any difference, but I’m connected directly to Wi-Fi with the Floodlight Pro3 Camera (not using an Arlo Base Station)
anyone else other than myself and 1 other having this issue, it is getting increasingly irritating, to the point where I’m thinking of turning notifications off, which defeats the object of having an Arlo Camera there at all.
Come on Arlo, please advise with a suitable resolution......
Getting double notifications on both Android and iOS. Have noticed the same 'green box' in one thumbnail and the absence of it in the duplicate notification. Happens regardless of which camera picks up the movement, so it must be app related?
Wonder if this would have something to do with the camera(s) recognizing separate 'events' as someone/something moves through the activity zones?
fenton11,
Thank you for the information. I've escalated this topic to the development team and will provide an update once I have more information.
I have been getting them for about 2 days or so but I have a current subscription so not sure if has anything to do with a sub. I haven't noticed them looking any different.
For some reason this past week my Arlo app has started giving double notifications to all event triggers on my phone. It's never done it before, the app doesn't appear to have updated since last month so nothing has changed there. I've tried everything to stop it from happening, even deleted the app and reinstalled it.
My wife is granted access from my profile so she has the app installed on her phone and its happening on hers as well.
I have to keep muting the notifications which defeats the object somewhat.
Any ideas?
iPhone 12 Pro, iOS 14.4, Arlo App 2.23 (1761), Pro 4 Camera on firmware 1.070.11.2_38
Actually just checked and it says 12/18/20. It has renewed though as everything is working with smart. They have been having a problem with billing but don't think the double notifications has anything to do with that. It is annoying though. I thought that it may be since I didn't update IOS to 14.4 but that didn't fix it.
For those experiencing this issue, are you able to provide a screenshot showing the double push notifications?
Thanks,
JamesC,
It is not easy to take a screen shot to display the issue?
1. A notification sound is made, with a notification display at top of screen with time stamp.
2. If you hold finger on notification, it enlarges and shows a stationary picture of the item that was moving with green box around item.
3. You release finger and notification disappears.
4. 10 seconds ish later a second notification sounds and pops up at top of screen with same time stamp as before
5. Hold finger over notification, it enlarges with same enlarged image but without green box around item that was moving.
6. Release finger and notification disappears.
7. Only one red circular notification badge shows on app on home page, and only one notification badge when you open app to view for the 2 event sounded notifications.
I can’t take screen shots quick enough to display....
JamesC,
correction to item 7.
There are 2 notification badges on app in the Home Screen, and 1 notification badge in app when opened, for the same one event.
When the second comes the first notification is gone or covered up by the second. They are the same timestamp about 10 seconds or less apart. EDIT: From what I noticed it only counted as one notification on the device page.
Recently, I get weird notifications on my Apple Watch. I get the first and original notification, but then a short time later, I get another notification for the same event but with a different time. For instance, if my back yard camera detects my dog and we let her inside, I get that notification. Video records that event for 2 minutes. Now the dog is inside before that 2 minutes is up. I then get another notification say 2 minutes later for the same event, but no video.
While I was typing the above, it just happened. 3:16pm notification at my back yard. I let the dog in within the 2 minutes that the video records. At 3:18pm, I get another notification for the same event, but not video is recorded, so a false notification.
I believe this started when I installed iOS 14.4. This second notification is weird on the watch as well as there isn't a full alert sound and the screen quickly disappears.
Anyone seeing this or have a suggestion
Here’s a link to a video I recorded showing the double notifications. First notification has the green box, second none.
https://www.amazon.com/photos/shared/r1gLaoLwTHSUE15lOOYbcQ.Yqhryn0AuqN5BtnYJ1Lj4_
