  • 6 Replies
  • 3146 Views
KD10
Since upgrading to the Arlo Secure Plus subscription I'm unable to record on my floodlight camera, and doorbell. The 'Record Video' option is greyed out when I try to edit the rules in the modes
A cloud side fix was release that should resolve this issue. Please try again and let me know if you still experience the same behavior.
6 REPLIES 6
Did you double check that the floodlight and the doorbell are both listed in the subscription plan?
KD10
Hi Stephen - thanks for your response. The subscription is showing “3 of 3 camera(s) participating”…presumably that’s what you mean when asking if the cameras are listed in the subscription plan?
Yes.  FWIW, you can also select "manage cameras", and it will give you a list of the cameras in each subscription (and list cameras w/o a subscription under "no plan").
You should be able to create a custom mode with recording then.  Have you tried both using the phone and a PC browser?
KD10
No luck with custom mode or any other mode, on either phone or PC browser 👎
KD10
I contacted support to be told that this is a part of a major incident that is affecting many Secure Plus subscriptions. So for now there is nothing that can be done. Engineers are working on the issue 🤷‍
Having never dealt with support before now, I'm keen to understand from other whether this a "general" response that people tend to get?
  • 6 Replies
  • 3147 Views
