  • 2 Replies
  • 1724 Views
fraymorejr
I have installed 4 of these Pro 3 Floodlights, one at each corner of my home. When one is triggered, the others follow suit and soon after I have a quartette of a light show. I've turned down sensitivity to the lowest level, no love. I've turned down the light settings to the lowest level, still no love. I finally relocated 3 of the 4 from the corners of the house to the center of each wall, this solved the problem for 3 of 4, now i'm stuck with an extra floodlight cam, because I can't install it anywhere near the other 3 due to sensitivity to light of the other floodlight cams.
fraymorejr,
When adjusting sensitivity, are you making the adjustment within your active mode?
How do I change the motion sensitivity on my Arlo camera?
fraymorejr
Yes, that it correct. Thanks for responding
  • 2 Replies
  • 1725 Views
