- English
- Floodlights
- Arlo Pro 3 Floodlight
- Re: Arlo Pro 3 Floodlight Camera Stopped Recording...
Firmware : 1.080.25.1_32_e230cb8
Hardware : FB1001AerH6
Worked fine for months, then stopped recording. I've reset 3 times, and swapped it's location with one of my other Arlo (Pro-4) cameras. It's on a solar charger and after reset will work for a day or 2 then stops recording again. All other cameras work fine and so does my video doorbell. It detects motion and I can record manually. Yes, I have a paid subscription.
Did you double-check whether it is armed (in the mode list).
Yes
Can you livestream after it stops recording?
Yes, I can live stream, motion light detects motion. Just quits uploading. I reset it again for the 4th time, and it's been working for 2 days now. We'll see how long it lasts.
