- English
- Floodlights
- Arlo Pro 3 Floodlight
- Floodlight not staying on for set duration in sett...
Floodlight not staying on for set duration in settings
Hello I have set the flood light duration to 300 seconds but it seems to go off pretty quick. (less than 1 min)
I do not have it hardwired to power but I do have the solar panel that has not been installed yet. Will it follow the duration when it has the solar panel connected or does it need direct power for this?
Thank You
The solar panel is just a trickle charger and won't supply current like AC power does (especially at night).
The "record until motion stops" feature requires that the camera be able to detect that motion. If the motion stops or moves out of the detectable range the recording stops and will start again if motion can again be detected. You can test for the range in your environment by walking back and forth in front of the camera, slowly increasing the distance to the camera.
I suggest using a timed recording instead if the current config doesn't get you what you want. It can only be set to 120 seconds but that may be enough.
wichie13,
I will pass your feedback along to the development team for consideration.
Thanks,
