which one should I buy, arlo pro or arlo pro 2
  • 4 Replies
  • 2461 Views
Mauricio11
I need to buy security cameras tomorrow, I was thinking about pro 2, but I read many comments that night vision is bad and they are constantly disconnected and that the previous model arlo pro is superior in night vision, please help me urgently to take a good decision
meier3283
Try the Pro 2, they aren't all bad, and if you don't like them, return and try the Pro.
Mauricio11
The problem is that I will take them to Mexico, so returning them is not at option. I don't understand why if both have the same hardware pro is much better in night vision than pro 2.
If you must buy Right now , the Pro, after a month with fw updates I think all the issues in the Pro2 will be close to fixed
Mauricio11
Thank you very much TomMac (Guru), all the problem must be a software issue or could be hardware, I ask you that because of the possibility of Arlo soliciting exchange the cammeras.
  • 4 Replies
  • 2462 Views
