Ghosting in Night Vision Mode
I have recently purchased the Arlo Pro 2 1080p camera system. I have noticed a ghosting effect on the footage (see below). I have restarted the base unit and power cycled the camera by taking the battery out. Signal strength is 3 bars.
Any idea what might be causing this?
Ghosting
ghosting has been around for a while now... it can be interference, server based issues or compression and loss of key frame ( do a search ).
It has never been locked down....tho for me it comes and goes every now and then. Doesn't last long term.
I had it, but don't any more. Only change was removing my hooded silicone skins. (I cut the hoods off) I'm not saying that was the cause, but it solved that, along with the hazy night vision I was seeing.
- David
