  • 1155 Views
ldm1417
Hi All,
I'm about recording of the video clips to the Hard Drive, which is attached to the Base Station.
Will I have an access to the recorded clips from my PC?
Is there an option to record ALL the clips always to both places – to the cloud and to HDD?
Is there an option do not connect the Base Station to the Ethernet/WiFi Router at all, so all the video clips would be recorded/sent to the attached HDD only?
Thank you!
No, the drive must be removed and then viewed by the computer with a prgm that reads mp4 files ( you can not access directly from the app/web prgm )
They do this automactically if there is internet connection
NO, the HD will record videos if previously set up to do so and the internet is lost, but you will not have any controls / commands to the base/cameras.... It is meant only as a backup
ldm1417
OK, so if I understood you correctly, the video clips will be stored in HDD in any case - either there is an Internet connection or not.
If there is an Internet connection then the clips will be stored in the cloud and in the HDD - the same clips in both places.
If there is no an Internet connection then the clips will be stored in the HDD only.
Did I understand you correctly?
yes... if the record function is set up before the internet goes out
As mentioned tho, you will have no way of sending commands to the unit
  • 1156 Views
