Does an adapter exist that adapts the pro 2 micro usb to the magnet? Maybe a short cable?
My pro 2 solar panel quit working. Where can i find one?
@dbharness wrote:
I need a new solar panel
Arlo no longer sells compatible solar panels. So you'd need to get either a used Arlo panel or a new third party panel. I am seeing a third party panel that claims to be compatible on Amazon for ~ $45 USD.
@dbharness wrote:
i want magnetic plug adapters if they exist.
There is no adapter to go from magnetic->microUSB.
You can still get a compatible outdoor charging cable (with integrated power adapter) from Arlo.
There are several third-party chargers with detachable cables out there - indoor rated cables+chargers can be found for less than $25 USD.
No.
Can you explain what you are wanting to do with such an adapter?
charge the cameras.
both
2 separate questions. I need a new solar panel and i want magnetic plug adapters if they exist.
On camera is high and needs a solar panel.
This is why I doubt i will buy more Arlo devices.
Arlo quit supporting my system very quickly.
pump and dump. Cannot trust arlo.
