Is it possible to delete all videos in arlo app at same time on andrid phone?
(Samsung S8+) and how?
Only on a per day basis but using the usual Android multi-select procedure.(long press and then select). You can use the new icons at the top that show empty and filled squares to (de)select all. However, I'd strongly discourage you from doing so since too many folks then want a video back which can't be done. Leave the videos and just let them fall off your library according to your plan (7 days for the free plan).
