Firmware 1.125.5.0_17202 H3
I have an orange circle with an exclamation point inside a triangle in camera view..what does this mean?
G410,
This icon will display if you have CVR or Activity Zones enabled on your Pro 2 while the camera is not plugged in. The purpose of the icon is to indicate that these features will not work unless your camera is plugged in.
I just started using Arlo and am learning things as they come up. As I was messing around with the "Activity Zones" this orange circle with an exclamation point in the middle appeared. I have since taken off the activity zone but it still appears.
What is this alert telling me? I assume once I address it, it will disappear. I can't find this information anywhere. Thoughts?
Do you have your Pro 2 camera connected to external power?
If not there is a warning that activity zones will not work unless connected to external power.
"To enable Activity Zones, please connect your device to AC power. You can still edit, add or remove at any time."
I don’t like having an alert message constantly on the screen for this camera.
Thank you for he help.
Are your symptoms similar to this thread https://community.netgear.com/t5/Arlo-Pro-2/Arlo-Pro-2-amber-warning-triangle/td-p/1541118 ?
PS. This whole forum is on the Arlo Pro 2, a more descriptive subject line is helpful, maybe a synopsis from your post, "orange circle with an exclamation point inside a triangle in camera view"
G410,
No activity zone, no CVR. Never. The icon just started showing up a few days ago out of the blue. I went into the activity zone and “reset” just in case, which had no effect. I also checked CVR. Icon still remains. Is it not standard interface design to display a helpful message when the user taps on such a warning symbol as to what the actual warning is?
It's a bug. Just delete the Arlo app and reinstall it and the icon will go away. I had to do this on Friday myself.
