motion detection not working - Arlo Pro 2
Motion detection on one of my Arlo Pro 2 camera stopped working. I have tried running motion detection tests on the camera. The senstivity is set to 100%, but I still do not see a blinking light. I have two other cameras that came in the set and they work fine. Any suggestions? Thanks.
You can also try removing the camera from Settings, My Devices and resync to see if that helps.
I have had the same problem since yesterday. 2 cameras working the third the motion detection does not work. I have tried everything eg re syncing, delete device, re boot, charging the battery, turning up and down sensitivity and still no luck. Only had the cameras 3 months. Any ideas?
Who did you call Arlo or from where you bought it from? Thanks
Dnmneil,
Are you using a custom mode or the default "Armed" mode? Is the running man icon on the camera widget for the affected camera showing as gray or black?
I have tried the default and a custom one with same result....no detection. The running man is shown as black
Thank you all for you advice. Here is what I did to fix the problem:
- I removed the device from the list of cameras.
- I removed the battery from the camera and then reinserted it.
- Finally, I resynced the camera with the base station, and viola, it is now working again!
I will try that. Thanks
