So camera volume is a whisper just spent half a day setting up system and an hour with tech support who eventually said the volume I am have is normal volume It’s a whisper! I’m using iphone7 and iPad and a AirPort Extreme router. PleAse help so I don’t have to climb back up and remove and take it all back. Thanks. Andy
Did you look at the tiny Mic and Speaker holes at the bottom. This system does not have a large speaker\mic. This system is ment for the average consumer and if your seeking a Big loud speaker you may need to look at profesional grade systems. Just looking at the camrea size when I got it I knew it wouldn't put out much sound.
If You Got Em....I'll Chew Em!
Netgear & Arlo Beta Tester
Try using a computer browser to see if it's better. If so, it's because you can change the computer mic gain where you can't do that on a mobile device (I wish they'd add it in as a new setting in the OS). ALso, I was told that the camera speaker should be within 3 feet of the person so different positioning may help.
