Is Arlo 2 faster than Arlo 1 or does it just have the 3 second back and 1080?
What controls the speed of Arlo detection? Is it internet speed?
Detection is via a PIR sensor though under power, the Pro 2 combines the PIR with pixel detection to allow zones to be enabled. The lookback feature is also only available under AC power.
I would say the Pro 2 has marginally better detection but it's not hugely better unlike the jump from Arlo HD to Arlo Pro.
Not sure if connection speed has much effect
