On my iPhone 7 using the Arlo app with Arlo pro 2 camera system, sometimes my phone will start playing audio from a recording in the background. Seems like a bug with the Arlo app. Anyone else have this issue?
Hi @Ray_Finkle,
Does this issue occur when you're opening the app right away? Or is it when you exit the app? If you're exiting the app, make sure to close the Arlo app out to not have any audio playing in the background.
