I recently purchased my Arlo Pro 2. Love it, so far. I did get an error message on one of the cameras "AC power has been disconnected from your Arlo device. Activity Zones are currently disabled."
What does this mean? I plugged the battery charger into the camera but the error comes up and the battery is fully charged. Advice from the community is greatly appreciated.
MikeG
Did you get the message while it was connected to power or after you disconnected and then reconnected it?
What version of firmware are your cameras running?
The Pro 2 have extra features that work when running on power, in earlier version of the firmware there used to be a message to warn you when the camera was not connected to power.
I have not see these messages in a while, at least since the last firmware update.
Hi, Streak2
I am running firmware 1.124.1.0_15483.
I reset my router because the base station had a orange light (internet service).
Then I resynched it and the warning light went away. So,I would say that's it?
thanks,
MBG1951
Whichever one make sure you do insert and the micro USB pins are engaged, otherwise surprise it gets an error. But of patience and fiddling with care.
I do not think it was the charging cable.
the error message went away after I resynched it.
Go into the video settings for that camera and see if you set up any zones.
If you did, then if power is removed you will get the warning as zones will not work without external power.
I had set up a detection zone on one of the cameras and it required AC power to continuously monitor the zone. I did not realize that feature was necessary.
When I removed the zone monitoring feature the warning message for camera 3 went away. Another feature that I noticed was that the order of the cameras had reverted to the previous state. when I initialized each camera to synchronize each to the base station.
When a camera setting is changed to have an active monitoring zone, then that camera goes to the bottom of the the order. Of the device display.
For example, I had cameras in order of 1, 2, 3 & 4, in logical order. When I activated the monitoring zone on camera 3, then the order of the cameras in the device display changed to 1, 2, 4 and then 3. I did not notice this at first but later I discovered it when I did 2 things.
When I plugged AC power to camera 3 then the AC warning went away. But the order of devices was still 1, 2, 4 3. It was after I had eliminated the active zone monitoring for camera 3 that the order of the device display had reverted back to the logical order of 1, 2, 3, 4 that was initially set up when I synchronized the cameras.
My thanks to the Community for all the help rendered to me.
Remember that you can change the device order under settings.
Well done for figuring this out.
Remove zones and CVR and the message will disappear.
