  • 12 Replies
  • 5849 Views
torum
Trouble to synch arlo pro 2 with basestation. Intial synch was successful. but being updated firmware after that the camera disappears and does not come back in the arlo app even though it is left for a day.
Tried disconnect or restart the basestation or camera, but nothing happen. How should I do for synch again??
torum
Hi, guys,
Having communicating with Netgear support my case has ended up to return goods. Deficiency might be in that product. Thank you.
12 REPLIES 12
Open and pull battery, then replace
Use REMOVE DEVICE in settings to make sure settings for camera are gone
Power button reboot base ( off -on, let it come online first before next step )
Resync as if new to bring back
torum
I have attemped as advised, but not suceeded. Pilot lamp in the camera stayed blinking in blue at same pace until timeout. I have tried this a couple of time, but same then not resynch. Should be any other ways done??
torum.
Restart your base station and bring the camera close to the base (within a few feet) and initiate the sync process again. Are you still experiencing an issue?
torum
It doesn't work...
torum,
What devices show in your Arlo account under Settings > My Devices?
torum
Basestation, 2 arlo pro cameras which synch was succeeded. However, doesn't show the third camera, arlo pro 2, I want to synch. It used to show that until I removed.
When pressing the base sync button, be sure to only briefly press it - don't hold it. Does that work?
torum
No, it doesn't...
Have you tried to sync with it plugged into the charger? If that doesn't help, open a case with support here.
torum
I did that, but it doesn't work.
torum,
Please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
torum
Hi, guys,
  • 12 Replies
  • 5850 Views
