Arlo Pro 2 vs. Arlo Go (for Cellular)
Now that I have three new Arlo Pro 2 cameras mounted outdoors and running off my home wifi/Arlo base station, NetGear introduces Arlo Go, which uses 4G LTE from (my cellular carrier) Verizon. Can the Arlo Pro 2 cameras be configured to work with VZW 4G LTE? I ask because the signal of one of the cameras is not ideal.
No that's not possible.
The GO has an internal sim card which allows the cellular communication.
You could look at either moving your base a bit closer or adding a second base and attaching the closest cameras to their respective bases all on the same account.
