Should the pro 2 camera be plugged in and have the battery installed 24/7 or will this burn the battery up with the cord attached ? Should it be one or the other and not together except for charging only ?
Wayne
Wayne
Depend on your setup.. It's ok if you decide to plug it in with battery inside.. It will not burn the battery but it would also be good if you let the battery run itself too to have its life-cycle.. The best way to do this is to get yourself a smartplug and set a schedule when you want to run battery only and when to start charging them.. This is my current setup and it works very well for me. It helped me alot with the previous firmware which it made the batteries drain for a short period of time.. I would definitely recommend this kinda' setup if you have access to neareast outlet.. Goodluck!
