Five days ago, all 5 of my arlo pro2 cameras stopped working. They all have full battery (2 are direct powered). They do not give "Live View", nor do they record anything to my library. They all worked well till 5 days ago.
The base station has all 3 green lights. The internet connection is working.
Just solved all my problems. I disconnected the power to the arlo base, plugged it in again after 10 seconds-then everything came back.
Thanks.
Have you done an truble shooting before comming here ? If so what have you tried so far ?
i.e. restart base station, resync camreas, restart router, restart modem....
If You Got Em....I'll Chew Em!
Netgear & Arlo Beta Tester
Thanks.
Good to hear it's resolved.
