UPDATE: (Adding translation from Google Translate) arlo pro 2 how to set / select alarm sounds in case of alarm
Frågan gällde egentligen varningen vid larm man får i telefon.Hitta det i inställningar i telefon.Problemet löst
UPDATE: (Adding translation from Google Translate) The question was really about the warning in case of alarms you get on the phone. Find it in settings on the phone. The problem solved
With the Pro-2 system with a VMB4000 base, the siren is built into the base station, and there is only one sound.
You can choose whether you want the siren to sound (or not) when motion or audio is detected, but you cannot chose what that sound will be.
