Hello,
Since a Dec2019 update my zones aren't working anymore ( with Solar panel plugged), anyone saw the same?
*isn't an Arlo solar panel, but I think makes no difference. (shouldn't)
I already reboot, unplug and plug again, still, I create a zone and isn't working properly.
any tips, help?
thanks in advance,
Miguel
Many of the cameras need ac power for zones... the solar panel is good for recharging but not the zones ( unless the zones work on battery like the newer Ultra )
Thanks, but the point is: was working previously. not now.
Are you using cloud activity zones (which require a paid subscription), or local activity zones (which require AC power)?
Local activity zones don't work with the Arlo solar charger.
Is the system telling you that the camera needs to be AC powered?
