Has anybody had any trouble with woodpeckers? One attacked one of my cameras and put a hole in it just below the lense.
No but that's a cool story. Sorry about your camera.
Do you have any pictures of the birds in action?
You could try selling them!
Just another user
One Pro 2 camera was attached by a woodpecker three times in one week. angry woodpecker
damaged Pro 2
anti bird reflector discs
**bleep** woodpecker got mine today. Won't let me upload the video but he was hammering away at it for a solid 45 minutes.
Sorry about your luck but that’s freakin hilarious and the picture is awesome.
Same thing happened to mine. Put a hole in the smoked plastic under the lens. I think they are attracted to the IR light.
One got mine as well. It's no longer detecting motion. Too bad they used plastic and not glass. Is this sensor a replaceable part?
I haven't seen a woodpecker since September! These anti-bird reflective disks work great. Found them on Amazon.
Gdela
An animal attacking a camera is far from arlo's fault so don't see them doing anything they could or would do about it.
That thought had occurred to me. What the heck can Arlo do to protect these things from, say, bear attacks?
Arlo could advise on protection strategies, but I bet there is someone out there willing to see a 'pecker-proof enclosure. Maybe something designed to keep squirrels off of bird feeders would work.
Just another user
Yea, On rings forum someone posted a vid of a bear attacking the cam. Had some serious teeth marks.
They replaced mine. Arlo isn't the only manufacturer to have a woodpecker issue. They could remedy the situation with a glass lens rather than plastic.
Thanks for the suggestion, I will try those out!
I also have Ring outside, The peckers have not attacked those!
I appreciate your response!
A glass lens? lolol a woodpeckers beak can bore holes in oak trees what do you think he would do to a glass lens.
Exactly they are are like hitting something with a mini jack hammer Glass would easily crack it if not break it.
I ordered these reflectors through Amazon. And they seem to work this camera and the one in the back have been tagged by the Peckers...they still work and will not replace the cameras, unless they stop working. They’re not cheap and I wish Arlo would have a solution for this, such as a case with some type of protective acrylic see through cover. Hope this helps!
Was wondering why one camera stopped detecting motion. When out to find it also had been attacked by a woodpecker. Camera still works, just no motion. I set up a near buy camera to start this camera to start also. Have to see how this works.
If they can make Cell Phone Screen Protectors, how about Arlo Camera Protectors!
I would assume it would interfere with the sensors in the lens unlike a Cell phone screen. There are covering but not for the lens and sensors itself.
