Hello, my camera will not detect motion. I've had these cameras about 4 months and one of the two has recently stopped detecting motion. It doesnt even work for the motion detection test. I have powered everything down and reinstalled/resynced and nothing. I will not detect motion. I can record on live and it will detect sound to record but not motion. Any suggestions.
Have you tried removing and re-inserting the battery in the camera to force it to reboot? If so, you might need to remove the camera from your system and then add it back in.
Brian
True, it could be the latest firmware. Try switching a good camera with one that is not working and see what happens.
Brian
What mode are you using? (the default "Armed" or a custom mode)
If you create and use a brand new custom mode with rules for motion detection, do you see the same behavior?
I’ve tried Armed and custom and still no motion detection 😞
