Hi, i am planning to buy Arlo Pro 2 cameras. I leave in Canada, in winter we have a lot of snow and temperatures go -30 celcius. If i use the magnetic mount, will they hold the cameras??
The magnets aren't the problem - they'll hold fine. The camera and battery is a different issue since the camera will shut down at -4F/-20C, probably to protect the battery. Use of AC power may help since the camera will be operating all the time, generating some heat.
Thanks for the information
