STABILITY OF Outdoor Mount in Black (VMA4000B)
- Email to a Friend
Recently purchased Arlo Pro2 Cameras. Up and running w/o issue.
I installed half-sphere magnetic mounts (exterior of home) where I thougt I wanted my cameras. Super quick and easy. The magnet is STRONG. This was the best way for me to 'test' the camera location for a couple of days before a more permanent install.
I feared wind or the hit of a basketball/football might knock off a magneticly mounted camera. I also thought for exterior use, dirt and debris would weaken the magnetic connection/strength. I decided I should use something that is more "locked on" to the cameras.
Removed the half-sphere magnetic mounts. Installed a couple of the VMA4000B mounts easily in under a minute. Here is my concern.
The mount screws onto the camera and seems tight. But it's only one quarter-turn that secures the mount (attached to camera) to the wall-plate (that is screwed into the wall). It only takes a quarter-turn clockwise (upward) to disconnect the mount and camera from the wall-plate. In other words, my fear is... one hit of an upward moving basketball/football and the camera will come down.
Does anyone else have this concern? Have I maybe installed the mount plates incorrectly or not secured the mount itself properly?
Thank you.
- Email to a Friend
I have to say I'm not a fan of those mounts. I prefer any other mount to those. I've used both Arlo and generic mounts with great success.
As for the magnetic mount, the magnet strength/connection doesn't degrade over time/dirt. I've used them outdoors for years with no movement/detachment. That said, a football (or squirrel) could certainly know the camera off in certain situations.
