  • 2 Replies
  • 1170 Views
kgkerl
I am considering purchasing an Arlo Pro2 system, my question is: Will the system work with a wireless internet connection? I use verizon Mifi and US Cellular Mifi, both connect wirelessly. Both are 4g. Will the Pro2 system work without a cable connection?
Sort of , the Pro/Pro2 systems require a base unit to function and the base needs an ethernet port....
but what you could do is get a wifi extender with an ethernet port and plug the base into that.
As long as you have a good upload speed  it should work fine ( Arlo reccomends at least 1 Mbs up, but I think 2 is better )
kgkerl
Thank you much for your help.
  • 2 Replies
  • 1171 Views
