  • 6 Replies
  • 2608 Views
Mginno
Can I give Extra camera to My son to use on his system?
Streak2
Master Master
Yes, that way around will work. Pro 3 camera on a Pro 2 base will not.
6 REPLIES 6
Streak2
Master Master
Yes you can. If it's one that you are currently using then use the app to remove the device from your system and then he will be able to sync. it to his existing system.
Mginno
Forgot to include detail..he has Arlo pro 3 and I have pro 2; does that make a difference? Will pro2 camera still work with pro 3 system?
Mginno
Thank you!
Streak2
Master Master
Mginno
Thank you so much for that information! So appreciated.
Streak2
Master Master
I need to modify my comment above.
The Pro 3 is not compatible with the VMB3500 and 3000 bases but is with the newer bases.
See below.
https://kb.arlo.com/000062253/Is-Arlo-Pro-3-backwards-compatible-with-my-existing-Arlo-system
  • 6 Replies
  • 2609 Views
