What kind of change are you seeing? A camera still has to maintain connection with the base even when not active.
I have 2 Arlo Pro 2 camera's camera A is the one that picks up the most motion movements,
Camera B has not picked up a motion for 7 days they battery on camera B has discharged down to 89% the same as Camera A
I got 4mths battery from camera B, and usually get 6wks from camera A
Does anyone know why Camera B is discharging at the same rate as camera A
Could it be down to the distance between the camera and the base station?
Just another user
