Make security system recognize homeowners
Has anyone thought of configuring the Arlo Pro so that it can recognize when the homeowner is entering and exiting home? A signal from a smartphone or watch would enable this, and keep the amount of recording and number of times the Arlo Pro is activated to a minimum.
That is what the Geozone does
That's essentially what the Geofencing mode is for. Use a mobile device to set it up. Mode tab, select your base and check out GF.
