When you set a schedule and you use the add button are you adding one or just modifying the one schedule? Can you have Multiple schedules?
No, there is only one schedule per base station.
The UI isn't quite as clear on this as it might be. But when you select add, you are adding to the single schedule, not creating a second schedule.
