When front camera sensor is activated, why is back camera recording?
  • 2 Replies
  • 2713 Views
Don_Froy_8
When I set the alarm mode -Front and back camera only.
When front camera sensor activated ,why the back camera records?
Please help Thanks
That can happen if you have set the rule for the front camera to do so. For example, you set a rule for the front and then used Add Device when editing the rule to also include the back camera or if the rule uses the front camera to detect but the back camera to record. Check your modes and rules to verify they're set properly. Post screenshots of the rule(s) if needed.
Don_Froy_8
Thank you for your help
  • 2 Replies
  • 2714 Views
