Audio Detection Too Many Notifications
My audio detection goes off continually in the notifications. I have it set to Level 2 from 3. Question - If I decrease further to 1 or keep it at 2 will it still record (either motion detected or audio detected) at the normal level?
Hey Impress,
When adjusting the audio sensitivity, this will affect the audio detection. Motion will still be detected regardless (depends on what you set for your sensitivity for motion or if you turned it off).
