I want to delete my files, all at once. Instead one at a time. I am new to ARLO.
While you can select multiple videos per day using the Select, Select All on the web or long press on one and then select more in the web, I strongly urge you to NOT delete the, Too many folks then want to get something back and can't. Just let them roll off the number of days you plan supports or download them proactively.
