I've search and i don't see any reference to what this icon means? I only see it in the app, I don't see it when I login via a PC abnd browser. Thank you.
Try setting up a zone, save, delete the zone and save. Consider reinstalling the app. Any luck?
Can't see the image until approved but I'll wager it's an orange/amber warning triangle in the lower right. There's already various threads on this. It's a notification that the camera isn't plugged in so CVR won't be available. I can click on it and have it pop up the message on Android.
Yes, the camera is not plugged in and the icon is what you described. I have another Arlo Pro 2 camera that does not do this. I didn't see it in the manual, sorry for the duplication and not coming across the other threads. Thanks.
Jfow,
Check your camera settings and delete any Zones created for that camera. This message is displayed when you have activity zones or CVR enabled for the camera and the camera is not plugged in.
I went into the app and to the site and do not see any zones setup. I also do do not have a CVR plan. On the app I see the icon, on the site I do not. Thanks.
I reinstalled the app and that did it, thank you!
