had these cameras for a while and always had silicone covers on them. However one day some how they got deleted off the base station and once I added all cameras again. They were not the same. They didn’t pick up detection like they used too.
i went from having 400 notifications to 20 in 24hrs
Best answers
@toekneedice wrote:
is there any way to reset the camera itself?Not Pro 2 cameras.
You can try removing the battery for a minute or so, and then reinsert it.
Check the motion sensitivity and see if that changed when you re-added the cameras.
Thanks for the reply.
I checked and they were all the way 100.
Not Pro 2 cameras.
