One of my Arlo Pro 2 cameras appeared as offline in the app. Thought I may have missed low battery warning, but when I opened the camera I discovered water inside. Replaced battery with fully charged spare battery and the camera is not working. Also, when I put the battery that was in it on the charger the amber charging light does not illuminate. Any chance that giving them time to dry out will work, or do I have a worthless camera and battery?
I'd let the camera dry out, and then test it with a battery from one of your other cameras.
The battery might be a loss, but it also might be fully discharged. You could try this: https://kb.arlo.com/000052305/My-Arlo-Pro-or-Arlo-Pro-2-battery-is-dead-what-do-I-do But I'd make sure the camera is working first.
PS... the rice trick ( just like a cell phone ) will speed up the drying out
check seal on door
That sounds like a firmware update is occurring. In any event, remove the camera from Settings, My Devices before trying to sync. If no good, use the Contact Support link at the bottom here to use your warranty.
Even out of warranty they can walk you through trouble shootings steps, can't hurt except your time on hold.
