I have the Arlo Pro 2 system, but I have never looked to see if this works.
My baby monitor will work on the local network (iBaby) provided my mesh network is still broadcasting, even if it doesn’t have internet access.
Is that the case with Arlo? Obviously I know it wouldn’t work remotely but I can’t find another post where this is addressed.
Thanks!
Thanks!
Hi jdiddy, no it will not work on a local network only. It is definitely going to require that the base/hub is plugged in via ethernet cord to your router.
Thanks,
Jonathan
